Replace battery- lost codes?
geoffreyw
North Devon, England
CLK 200K Auto/Tiptonic Avantgarde
I need to have a new battery fitted. What codes, if any, will I lose .
Thanks Geoff
R171 SLK280, Smart R451, 997 C2S, VW ID.5, R1250 GSA TE 40th, CBR600FP
You will lose the memories on the windows and seats if you have memory seats. Depending upon how old your car you may need the radio code. To reset the windows open them and hold the button down for ~10 secs then close them and hold the button up for ~10 secs you will then get the one touch back.
louwdj
Will any damage ensue if another 12 Volt battery is conected to the jumpstart points in the engine bay whilst the old battery is disconnected and changed?
Google44
hi
have a look here under car section
www,unlocker-forums,co,uk
That is where I got my code from. you will need to register for free. dont forget to replace , with .
ALFIEBEARD
DUMFRIES
JAGUAR XF-R SPORT
No damage will occur as long as you get the polarity right, in fact this is the best way to keep all the codes.;)
Alfie B
Alfie B
Agreed, I did that with my W210, I connected another battery to the terminals under the bonnet whilst I changed the battery under the seat. The only point of caution is that once you have disconnected the battery your brain may tell you that the +ve terminal is dead so it doesn't matter if it touches any metal that isn't true of course as you have another battery connected so you could get some nice sparks and a fire if your really lucky.
