Replace Mirror indicator LED on c class
D
Davearp
Hi Can anyone tell me how to replace the indicator LED on passenger door wing mirror?
I can't get the mirror or casing off.
Many thanks
Welcome to the forum Dave,, a little more info please,,is the car a 202 or 203
D
Davearp
It's a 220CDI on 2003
OK I nave that info,,but I need an Email address you could pop it up here for a few mins and take it away in Edit later, or put it in your user profile
D
Davearp
ok. it's in my profile under bio
I have sent it :D:D
I have sent 2 papers
harpersimon
Southwest
2015 A200 AMG line
Having just done this on my car - its very easy - once you get that clip released!!
Looks like you will never get the casing off but you do need to be tugging on it when you press the metal retaining clip in. Then there are 2 small cross screws holding the indicator in -when you put the new one in you have to firmly push it into place to get it seated correctly and sealed.
Alex Crow
Super Suffolk
a wonderful 'free' service here (thanks malcolm), but even though saying "please" is free it is all too often neglected, sad really.
harpersimon
Southwest
2015 A200 AMG line
I know.. no more info unless someone remembers P's and T's!
Most members are very OK on this point,,it is the PMs off the forum that screw me up
yeh yeh
Hi Davearp, i had the same problem with my C320, i don't think its the led light, because the last a long time, does your mirror folds? if they do, its most likely it a broken wire,
to gain access to the wire,first you need to fold the mirror, then with a longish screwdriver there is a hole or a opening push the scredriver in untill the spring clip move slightly back,then at the sme time, push the mirror casing out, then you will see 3 srews
holding the mirror, undo those and you should see a conector,disconect, and you should be able fined the broken wire, its quite tricky to repair, but can be done, i had to do both of mine. hope of some help.
www.ckinsurance.co.uk
