Replacement brake hoses - what clips to use ? W124
franksm
mx5ireland.com
Hi folks
replaced the flexible rubber brake lines on my W124 with Goodridge braided items. While they fitted fine, the do not butt into the bracket mounted on the chassis that holds the flexi line to the rigid line.
While the brakes feel brilliant now, I don't like the way the rigid line isn't so rigid any more.
Before I start messing with circlips and the like, is there some clip or something that I need to use ? The rigid line has a spring-clip fitted, but there needs to be something on the flexiline to stop it going through the hole in the bracket.
Cheers
Frank
Tel: 020 8863 9233
