Replacement fuel pump
2SSB
MANCHESTER
ml 320 1999
Hi does anyone know where i can buy a fuel pump for a 1999 ml320
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
As i see it you have one of three chioces, MB dealer, Euro car parts or German and Swedish.
Normally ECP and GSF will give you a choice of two different makes the more expensive option normally being OEM
and you are SURE that you checked and found 12v ACROSS the two terminals at the connection to the pump housing? not just 12v at just one, using a body earth?
2SSB
MANCHESTER
ml 320 1999
and you are sure that you checked and found 12v across the two terminals at the connection to the pump housing? Not just 12v at just one, using a body earth?
yes have checked at two terminals on wiring and have removed pump and have connected direct to 12 volts and doesnt work
fair enough ;). just wanted to be sure. have you tried dronsfields, or pcs?
What is wrong with the new one that I put in the link above,,its new
2SSB
MANCHESTER
ml 320 1999
what is wrong with the new one that i put in the link above,,its new
ta to all ml320 now running but now radio sounds like the aerial is disconnected what next
The antenna amp sits in the back and the chance are that either the fuse is blown for the amp or one of the very thin center wire has broken in one of the plugs in the amp
