Replacement seal for top cylinder roof CLK
tooth_dr
W208/2001/CLK320
I need to replace a leaking cylinder in my softtop roof. It's part number A2088000072. I've seen a US company offering replacements. Is this something that can be done in the UK?
Thanks in advance
Adam.
As I understand it it's a fairly simple task to replace seals.
If you're not comfortable doing it yourself remove the cylinder and take it to an hydraulic specialist - they should be able to source seals in the right material.
Frontstep
T210 320cdi
Thanks in advance
Adam.
This sort of thing https://www.ebay.co.uk/itm/Mercedes...nder-Repair-Kit-R129-Roof-Seals-/151248219421 £12.95
<iframe width="713" height="401" src="
" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Ideally seals should be Viton. I doubt at that price the ones in the eBay listing will be
tooth_dr
tooth_dr
W208/2001/CLK320
Thanks guys. Are the R129 cylinders the same as the W208? I dont think they are compatible?
No they aren't. It was an example of the fact these things can be fixed.
Joe172HawkXP
CLK230 Komp W208
Joe172HawkXP
CLK230 Komp W208
Hi, I have the same problem on my 1999 CLK230. Apparently it is a common problem due to poor quality OEM seals, Does anyone know how to dismantle these (black) 208 8000 072. 172, and 272 cylinders? Seals are available from a company in Germany. Thanks for any info, joe
