Replacing a key case on a W203 key
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by curious, Oct 31, 2012.
  1. curious
    curious Senior Member
    322
    85
    Nov 17, 2008
    Your Mercedes:
    Only the Vito left! OM646
    I've just acquired a new key case from eBay for my W203.
    (The button blisters had split on the old one.)
    How do I get the PCB out of the old key and into the new case?
    I'm concerned about any little plastic lugs or similar I'm likely to break, or, God forbid break the PCB in the prosess.
  2. television
    television Always remembered RIP
    164,074
    309
    Your Mercedes:
    Best to have a knife with the tip bent at 30ยบ and slide it in just enough to be able to slide it along to release the catch that you can see here on that white nylon block, the hook the pcb out
  3. OP
    curious
    322
    85
    Nov 17, 2008
    Your Mercedes:
    As ever to the rescue.
    Thanks Malcolm.
Share This Page
