Having problems with the front right dash speaker on my 1991 300CE any ideas how i get to the speaker? Ive tried the cables on the radio and all seem fine, need to look at the speaker
Sorry Bob,
Thought I posted that on SPEAKER Replacement forum below.
Must have sent it by private message.
Take off the plastic strip at the side gently with a flat screwdriver (with
insulating tape on the end). Then remove the philips screws holding the cover. Remove the cover and there is your speaker.
Pascal
Thought I posted that on the speaker forum. Must have sent it by Private
Message.
Remove the plastic strip at the side of the cover gently (with a flat screwdriver
protected with insulating tape)
Remove the philips screws hold the cover and remove cover.
Then you will have access to the speaker,
I recomend changing........See other forum
