Just start at the rear end, and lift up. Something plastic might help to start it off.
Please not that some of the clips may lift out from the metal sills, just push them back down, you do not need the new clips.
Take care that the rear most one is also holding the rear side panel with a little U shaped piece, so just make sure that this clip is holding the rear side trim panel.
Also when re fitting get the front in place first so that it sits where they old one was, mark the end on the car with a bit of sticky tape as you cannot slide them along.
You lost your key ? Or maybe you need a spare!
Your vehicle imobilliser does not respond anymore?
WE CAN FIX THEM ALL !! Mobile !
Save Time and Increase Profits With us !
