Replacing the battery in the key fob
Amsy
Mercedes-Benz clk 240
Hi i recently bought a used CLk 240 key fob stopped working so I replaced the battery still not working I then bought a new fob case from Amazon for 9quid and swapped all the internal parts still not working any ideas ?
Does it start and stop the car?
Is it just the remote locking and unlocking that isn't working?
If it is just the remote unlocking there is a coil on the circuit board that comes adrift - you can if you're handy with a soldering iron solder it back on or replace it if it's completely snapped.
Did you buy a used key fob to use with a different car to the one it was originally programmed for?
A
Amsy
No it won't start or lock the car mechanic checked all the fuses and they were fine he said after replacing the battery I will need to reset it but I don't have a manual for the car
A
Amsy
No it was just the fob case that was replaced
You don’t need a battery in the key to start the car. There’s an inductive loop in the steering binnacle that reads the chip in the key.
Has the key ever worked ?
