Replacing the metal part of a W202 electronic key?
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by chizzel89, Nov 4, 2012.
  1. chizzel89
    chizzel89 Senior Member
    345
    Feb 27, 2011
    Pembrokeshire
    Your Mercedes:
    Mercedes-Benz C250 Turbodiesel Sport Auto. Estate. 1998. 180,000 mls
    When I go surfing I always lock the car up using the electronic fob (but with the drivers door still open). I then slide out the metal door lock key, hide the fob under the floor mat, shut the drivers door and lock it manually, then stash the door key under the car before I go in the sea. I usually reach round a rear wheel and stash it on top of a rear lower arm. However today it fell into the arm which is ofcourse full of holes and has a plastic cover on the bottom and it couldn't be retrieved. It seems to have fallen right in and is probably resting on the plastic cover which attaches to the underside of the rear lower arms.
    In the event that I can't find it there, how and where can I get a replacement?
    Just the metal door lock key, not the actual electronic key (Im well aware those are over £200!).
    Thankfully I have a spare key, so I'm ok at the moment.
    Thanks in advance.
  2. Blobcat
    Blobcat Moderator
    21,242
    7,861
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    I'll look out for your car next time I'm down a Newgale or Tenby...
    Yes the metal key is available, having said the plastic over comes off s with luck you should be able to get your key back.
  3. television
    television Always remembered RIP
    164,074
    285
    Your Mercedes:
    You can buy the blade only from MB
  4. OP
    chizzel89
    345
    Feb 27, 2011
    Pembrokeshire
    Your Mercedes:
    Haha, yeah there are so few C250 TD estates in Pembs, let alone ones parked at surf breaks that giving that info wasnt such a good idea!
    I've thought I should use the wetsuit key pocket, but then Id have to remember to leave a bottle of water outside the car to rinse the key off before putting it in the lock to get into the car (salt in door lock = bad).
    It has been raining here for 4 days non stop now, and I can't take the car down the garden to shed and thence to the ramp to investigate until it dries out a bit or I'll get stuck but I hope it's stuck there and that I can retrieve it.
    So I take it Mercedes can order a new one based on my chassis number?
    Do you frequent Pembs then? There's a huge lack of Mercs! Any of the german cars are mostly BMWs.
  5. Mark@RMK
    Mark@RMK Senior Member Authorised Forum Supporter
    534
    8
    Jan 4, 2010
    Birmingham
    Your Mercedes:
    115CDi Vito
    Mercedes will indeed beable to order you one with the chassis number and it will come cut and ready for use!
    Its around £27 I think.
    Mark
Share This Page
