Retrofit comand 2.5 to my 1999 w220 S500
Golden_rose
Indonesia
S class
Hi guys,
I have a 1999 mercedes S500 w220 that has a audio 30 without vk/rds.
I would like to retrofit a command 2.5 on it.
Can anyone help me the procedure of doing it and where can I get the wiring adapter.
Thanks.
Andrew
If you put the GPS antenna under the dash then no :D
G
Golden_rose
Indonesia
S class
speed sensor
Hi guys, I'm still trying to retrofit comand 2.5 on my 1999 s500 w220.
Does anyone can explain what the speed sensor means?
NW_Merc
Banned
Oop Norf
Mercedes W202
The speed sensor tells the speedometer how fast your car is travelling. Your comand needs it to give you a correct navigation set up and also if it has auto volume. Ring Comand online and speak to Alfie, he will tell you more.
