N
nmacc
Hi folks,
Quite new to this forum; any help would be gratefully received. Just changed my 1987 190 with 210,000 miles for a 1993 220TE with a mere 172,000.
I've managed to trace & fix a few odd faults on it, but I have a few irritating running problems. When cold she starts perfectly, but stalls when put into Drive; after about 3-5 minutes she's fine. Hot starting is fine. Could it be the cold start injector? Where might I look for the beast?
Another oddity is the way the engine performs above 4,500 rpm or so. Rev it with no load and somewhere between 4,000 and 4,500 she starts to cut out, as though a rev limiter was cutting in. When running under load this can happen at lower revs such as 3,500 and the problem stays until she drops below 2,500. I suspected fuel starvation, so I changed the fuel filter, but that had no effect. Any suggestions?
Also can anyone tell me if the 220 has one or two fuel pumps? (it was a bit dark under there!).
