Rivet size
Had a search and couldnt find anything.
Does anybody know the rivet size I would need to replace the drivers side window motor on a 208? Thanks :)
davidsw
cornwall
Jaguar XKR ,Jaguar S-Type, Porsche Boxster S
I think it is an odd size and people have used small bolts/nuts to avoid the arm striking the operating arm. If you use original size rivets you will also need a seriously strong rivet gun .
Nuts and bolts are fine but do use stud lock on them
cleverdicky
MB
Dont know the size, but I've used this company before, with good selection of larger rivets
And used a Stanley rivet gun. Which is excellent even for very large strong flight case rivets.
AdamG
Bromley, Kent
S320CDI (2003)
I believe that Mercedes use a steel rivet. I just did the regulator on a w210 and bought the Mercedes ones. They took some force to pop:)
I once riveted a door lock actuator to a defender door and after about a year the aluminium rivets failed through fatigue.
Adam
Frontstep
T210 320cdi
Bought a selection of stainless bolts, washers and nyloc nuts on Ebay very useful.
Button head keeps the projection down.
  • Moderator
Thanks all
giuseppe
Bournemouth
E220Cdi avantgaurde 2001
On my E class, it states 3/16 pop rivets, available from MB or screwfix, this could be common to all models.
