I am confident my Car has not been smoked in, but the liner to the Sunroof is decidedly grubby.
What do members use to clean the roof lining? A foam spray and cloths?
I also use wash powder in warm water for the carpets and seats, applied with a stiff brush. I haven't had to do my roof liner yet but I see no reason not to use it there. I wouldn't worry about the condensation, most of the water will be on you.
Is the chip in the windscreen repairable?
I had some chips repaired on another car and they remain visible to some extent. That's Ok though, it's the structural integrity you need to worry about. AFAIK chips can't be repaired twice, if in doubt pop along to your local Autoglass place and discuss it with them.
If you run a finger nail across the chip you can feel a little indent but it should be filled flush with the surface of the screen. If you can see the chip in all its glory then chances are it hasn't been repaired. Mine are faintly visible in certain light conditions. See what they say when they get to you.
Thumbs up
Passed MOT - emissions were close.
Thumbs up
