Roof lining W202?
Septic
Hi Folks
Checked my c180 W202 today after not using it for about 4 weeks
the roof lining has dripped down its still attached to the roof. How do i re fit it obivously it needs re gluing.
Any advise would be great.
Stephen
teddycatkin
cheshire cheese country
Hi Septic--not too clear on what you mean by "dripped down" ? if its come away at the sides remove the rubber trim at the top of the door shuts -stretch it back --use contact glue to stick it and replace the rubber trim over to hold it tight again !
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Please, please be careful which adhesive you use as I have similar problem on my C230K, but on the sliding roof panel of the sunroof (same material at the headlining) I have attempted to glue it with spray on carpet adhesive, it has just soaked through the material and now is just a sticky mess, now I have to remove the whole panel to replace it, which I believe will involve the entire removal of the headlining.
With this in mind it might be worthwhile to get the proffessionals to look at it and advise.
Dave Brooker
You should be able to get the headlining off the sunroof just by unpopping it at the front and then opening the roof?
At least you could with a W124...
Yes correct Dave of coarse and they all unclip, I can give details of most
Septic
It hasn't come completely lose its become saggy in the middle
i might get MB to try and sort it when its in for service.
Thanks for the replys
Stephen
Stephen
Are you made of money ??? use an indie
Septic
No just stupid :)
I might try double sticky sided tape.
