Rotating tyres...
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by Naraic, Nov 17, 2012.
  1. Naraic
    Naraic Moderator
    10,330
    942
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    ...is this still done at service time, or does anyone do it at regular intervals (assuming you don't have a staggered set up)? I ask because they seem to still do it in the US.
  2. E320mark
    E320mark Senior Member
    842
    3
    Jan 26, 2011
    Ballyclare
    Your Mercedes:
    E320 cdi sport 2007
    I have a friend who still swears by rotating his tyres! Every service he swops them round (diagonally)
    It's something I haven't really though about! He is getting almost three years out of a set though!
  3. peterwhayward
    peterwhayward Senior Member
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    E240 classic est 2000 2.4
    Are tyres not mainly " one directional" now?, so that really as long as the rears are the same size etc then you can only swap front to back and not diagonally. Which really negates any benefit of swapping them.
  4. Mic
    Mic Senior Member
    4,271
    127
    Nov 12, 2009
    Oxfordshire
    Your Mercedes:
    http://forums.mercedesclub.org.uk/showthread.php?p=941202#post941202
    Post #1176
    Best to avoid noisy unidirectional tyres and maximise rotation options.
    Google tyre rotation and all is revealed.
    Mic
  5. Frontstep
    Frontstep Senior Member
    7,391
    1,275
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    I did mine last week during sensor rings fix I don't think Mercedes take the wheels off.
  6. amb67
    amb67 Senior Member
    664
    Dec 28, 2007
    The Garden of England
    Your Mercedes:
    Mercedes-Benz C220 Coupe AMG, E320 CDI (S211), Aprilia RSVR
    That's correct, most services are completed without removing the wheels and if you ask for the wheels to be changed around they charge you £50.00 extra. :rolleyes:
  7. television
    television Always remembered RIP
    164,074
    309
    Your Mercedes:
    When my CL was last serviced they told me they never have time to remove the wheels, even though you are charged for that time on a B service
  8. turbopete
    turbopete Senior Member
    14,204
    324
    Feb 4, 2009
    Spennymoor
    Your Mercedes:
    2010 '60' Ford Mondeo 2.0TDCi Zetec (sorry)
    i swap mine front to rear as the fronts tend to round off with cornering forces etc, so i put them on the rear to wear them more evenly. the rears tend to wear slightly more in the middle, so it balances out. i get 4 evenly worn tyres rather than 2 rears with the middle slightly more worn than the edges, and the fronts worn on the edges with loads of life left in the middle.
    i only swap diagonally if wear rate dictates its necessary ie theres lots of roundabouts around here so the front left gets particularly hard worn, so if needs be i swap it to the right rear
  9. Myros
    Myros Senior Member
    2,728
    Aug 16, 2004
    Your Mercedes:
    R107, S211, R170
    I do them at least twice a year
    with the mileages we do. Still recommended in the owners manuals.
  10. Frontstep
    7,391
    1,275
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    Can I offer my wheel changing service £49.99 ?
    That should equate to circa £200 ph.
  11. television
    164,074
    309
    Your Mercedes:
    Would you be wheeling and dealing then
  12. SL55 Mark
    SL55 Mark Senior Member
    2,648
    354
    Oct 1, 2012
    South
    Your Mercedes:
    2004 SL55 AMG
    My rears are 285s and my fronts are 235s, so i don't think they are interchangeable. :D
  13. Frontstep
    7,391
    1,275
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    At £50 a throw I will.
  14. JBell
    JBell Senior Member
    12,063
    3,943
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    Shouldn't do it, tyres wear dfferently on axles, just replace when needed.
  15. television
    164,074
    309
    Your Mercedes:
    I agree on this one, for indeed they do :D:D
  16. yorkshire1
    yorkshire1 Senior Member
    1,036
    26
    Apr 10, 2012
    East Yorks
    Your Mercedes:
    "98 S202 C250TD Manual hybrid
    pressure
    your rears want letting down a tad
  17. turbopete
    14,204
    324
    Feb 4, 2009
    Spennymoor
    Your Mercedes:
    theyre set to the pressures in the fuel flap. as ive already said, if i swap them front to rear every so often it evens itself out. and they often get to below pressure anyhow, as i dont check the pressures as often as i should!
  18. Ricardo_e220
    Ricardo_e220 Senior Member
    1,259
    93
    Sep 16, 2012
    Newcastle upon Tyne
    Your Mercedes:
    R170 SLK230k 1999
    I thought that this was now claimed to be bad due to shifting the stresses put in the carcasses of the tyre?
    I only move front rear and back to balance out the tyre wear and because I don't like different tyres (which I currently have on my summers from those the garage put on)
  19. television
    164,074
    309
    Your Mercedes:
    You are correct and many of us are saying this here now:D
Share This Page
