wrichardson1999
Hi Guys, hopefully you can help...
I've a E200 (auto) on an 'L' Reg that I've had for about the last 5 years, I bought the car on around 95k and had the car converted to LPG. The car has now done around 240k but has started to develop problems!
The car is fine on acceleration/normal driving, although when I slow down (crawl) or stop the revs drop through the floor then jump about, if I stop car either stalls or idles on very low revs.
What I've done:
Drained the heavy end from the lpg, cleaned lpg diaphram
Changed Plugs
Changed oil and filter
Air Filter
The plugs were supplied with a .8mm gap setting which apparently is the correct gap size BUT the plugs that were fitted by my garage were .89? The car wouldn't even start on .8 but when adjusted to .89 it at least starts and ticks over...
The car only stalls when hot!
Help
Anyone?
What should I change next?
Should I? can I change the engines idle speed?
Many thanks
Wayne
What I've done:
Changed Plugs
Air Filter
Help
Anyone?
Many thanks
Wayne
