rough idle when hot
japimport
The Emerald Isle
mercedes c200 sport,mercedes c200 elegance
hi there i have a c200 sport 95 when the car is hot the rev counter bounces all over the place it feels like it wants to stall anyone have an idea what it could be thanks maybe point me in the right direction
roofless
w124 e220 estate
have you done any work to the car prior to the fault?
japimport
japimport
The Emerald Isle
changed the spark plugs and engine mounts and new leads
roofless
w124 e220 estate
try the micro switch on the throttle body the acc linkage cam must tuch it to idle prop when hot
japimport
japimport
The Emerald Isle
what does the micro switch look like
roofless
w124 e220 estate
sorry mate i dont have any picks i can post .just make sure the throttle is returning all the way to the idle pos even if its only slightly short of the tiny switch if will cause rough idle its worth a look but may well be a other prob but its a start
japimport
japimport
The Emerald Isle
ok thanks will have a look
kth286
E320 Coupe 95
I hope you installed the correct non resistor plugs as specified by mercedes.
japimport
japimport
The Emerald Isle
i put ngk bcp6es in the car i bought the bosch ones and the car ran like crap haynes manual says what type bosch ones to buy and thats what i bought and then i got the ngk ones
kth286
E320 Coupe 95
don't know if Haynes is correct.
The plug types showing on current Mercedes lists are as follows:
Bosch F8 DC4
Beru 14F-8 DU4
Champion C11Y CC
Cost is about £2 each.
