Bob India
- Nov 14, 2018
- A-Class 2005 A170 PETROL AUTO (W169) Facelift Version
Hi Everyone,
I would be grateful for advice regarding my 2005 A-Class (W169). 40,000 miles on the clock. I bought it new so mileage is correct.
Symptoms are; Intermittent rough running and car shakes.
The car starts OK, then it's like one or two of the cylinders are turned off and the car starts to shake. Then a few seconds later it's OK again. This process keeps happening every few seconds, (Between 5-10 seconds intervals) and is getting worse. This happens up to around 40mph, then going above this speed, say around 50mph and above, the car seems OK. Also, I can't seem to do more than 70mph, the engine tops out at about this speed.
I'm guessing the ECU is switching something ON and OFF and cycling depending on a reading it is getting from some sensor..
I went to my local NON Mercedes garage and they used a LAUNCH code reader which gave its reading as codes ;
00F6-008 Plausibility check of values for components B28(Pressure Sensor) and M16/6(Throttle valve actuator) in idle and under partial load Lambda control OK.
00F6-004 Plausibility check of values for components B28(Pressure Sensor) and M16/6(Throttle valve actuator) in idle and under partial load Lambda control OK.
Given the symptoms and the diagnostics codes I have been given with the explanations, does anyone know what the problem is or where or what I should be changing?
I would appreciate help from those who have had similar issues and what was done to resolve the issue. I do most of my own car repairs so familiar with most aspects of repair.
Does anyone know what B28(pressure sensor) & M16/6(Throttle valve actuator) are? I have an idea of what the Throttle Value Actuator is but would welcome comments from all those who Actual know and/or have had this problem sorted and how..
Many thanks..
Robert
Many thanks..
Robert
