Do you mean the jacking point bung? or the jack pad, adjacent to the jacking point? If it is this, just go to MB they are about £10, just pull the centre large pin out so far (it does,nt remove completely) locate it and bang it in with the heel of your hand then tap the centre pin till its flush with the pad, very easy, incidently its not made of rubber but high density plastic.
