run flat indicator
kingsandgreen
cornwall
clk270cdi 04/ clk320cdi 06/ slk230 convertable 01
hi all, have clk 320, 06 plate, had new tyres on front plus a spring and ball joint, 1 day after back from garage have got run flat indicator and esp light on, took it back and they cleared fault with snap on code reader, 15 mls later lights back on. is there something the garage have done or do I need star to cure ?
run flat indicator says unavailable
John Laidlaw
Wirral
BMW 530d X Drive Tourer M Sports
Probably a stupid question but did you put run flats back on?
icarsoft MBII would clear the codes too if you know someone with one
K
kingsandgreen
cornwall
didn't have run flats on it before and no not run flats now. have got icarsoft 2, clears it then comes straight back on
rf065
Grossbritannien
Sounds like a speed sensor has been damaged? Or just coincidentally stopped working?
Russ
EmilysDad
Bury Lancs
ML350
..... have got icarsoft 2, clears it then comes straight back on
Does your car give you the pressure of the tyre that's flat? Or is your car telling you that you have flat tyre? My car does the latter & it's reset via the dash cluster ..... no iCarsoft required
Can't say for the ESP light :confused:
K
kingsandgreen
cornwall
no doesn't give tyre pressures has no settings on control unit for tyres, just has message as stated above, wouldn't be surprised if garage has caused some damage whilst working on car but pretty hard to prove when I don't know whats wrong
EmilysDad
Bury Lancs
ML350
My car tyre pressure reset is the same as this ML (though he does some faffing about :D)
The fact that your ESP warning light does suggest an ABS sensor has been disturbed.
'93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
If they replaced a spring they may have damaged the wire to the ABS sensor in the process.
An iCarsoft should detect that if you read the codes for the ABS
K
kingsandgreen
cornwall
yea maybe, abs light on now. tried to read codes on carcroft but abs not showing on the list, guess i'll have to find a reliable indie in southwest, any recommendations
John Laidlaw
Wirral
Mercare in Plymouth get good comments on various forum
With Turo, you can book and drive any Mercedes you want, wherever you want it, from local hosts across the UK, US, Canada, and Germany. Test drive cars you otherwise might never get a chance to try, or hire something interesting for your next holiday:
www.turo.com
