Run Flat Sensor
bertg
London S.E
B Class 2013
Could someone briefly explain how the runflat indicator on my 2013 W246 works please?
Cheers
Umberto
EmilysDad
Bury Lancs
ML350
Cheers
Umberto
If your car will tell you the pressure of each wheel, you have a pressure, temperature transmitter on each tyre valve that talks to a receiver in the car.
If your car says you need to check your tyres .... guess which one is flat .... the car uses its ABS sensors to monitor which wheel is going a bit faster than the others ie the one that's softer & has a smaller rolling diameter.
bertg
bertg
London S.E
B Class 2013
Makes perfect sense, Thank you.
Yugguy
Rugby, UK
C220CDI W204 Elegance Comand
There's a bloke 2 inches tall with his feet glued to the wheel.
If the tyre bumps his head he shouts ouch.
Tiny microphones pick this up and relay it to the ecu.
bertg
bertg
London S.E
B Class 2013
Is that supposed to be funny?:(
Yugguy
Rugby, UK
Just a joke, the question had been answered, I meant to no harm.
