533rockape
- May 21, 2016
- Location
- Redcar, Cleveland UK.
- e class 220
Has anyone got a towbar fitted to a post 2017 S class, if so where from, thanks in advance.
Thanks, Just the gen I'm looking for, I'll look into it.I have had a GDW towbar fitted to my S class, which is a 2015 model, ie preface lift. I presume that it will fit the post lift version as I doubt whether Mercedes would have changed the bumper mounting points? I also purchased a specific Mercedes wiring kit from Rameder in Belgium as Mercedes do not list one for my model. I was advised not to have it coded as it can leave a warning light on, which cannot be cancelled!! However, the electrics work fine, the bulb checking on the caravan works. I am not bothered about the fog lamps as I am unlikely to tow in fog!! Have not noticed any problem with the rear parking sensors, probably because I don't reverse very ofter. They can be switched off!! Coding instructions were included in the wiring kit.
Look at https://www.rameder.eu/towbars/mercedes-benz/s-class/w222-v222-x222/
