Brianooo
- Mar 9, 2013
- Location
- Preston Lancashire
- Mercedes E300TD Avantgarde estate 1998
Hi, My 1998 E300td S210 has brust a hydraulic pipe. The problem has been caused by corrosion. Where can I by some pipe to repair the broken pipes. I thought it was just brake pipe but the front to rear pipes are a larger diameter than brake pipe.
Brake pipe is used for the hydraulic system after the load sensing valve but from the pump/fluid resvoir to the load sensing valve it's slightly bigger. I have measured the front to rear pipes a little under 7mm were as the brake pipe is a bit over 5mm.
Any suggestions on where I can obtain the 7mm (ish) pipe I need?
