S210 trunk lights not working
Linuus
crawley
w210 wagon
Hi guys. My s210 today, doesn’t light up the 2 side trunk lights and the tailgate light to :/ the bulbs looks ok. The fuse for underneath the back sit, all fuses looks fine. Any advice?
Linuus
Linuus
crawley
w210 wagon
Will replace fuse and update, but now I’m traveling so only next Tuesday will update.
Linuus
Linuus
crawley
w210 wagon
Put a new fuse in notwithstanding how good the current fuse looks.
I have check the continuity of all fuses with a multimeter
Linuus
Linuus
crawley
w210 wagon
So I have replace today fuse number 3 from the from fuse box. But will no light in the trunk :/ and I can’t see any loose wire too...
SRE
Norfolk
R230 SL500 2005
OK this may be a silly question but are you sure they are not working? I only ask as I thought my trunk light on the R230 wasn't working until I discovered that it is also controlled by the interior light switch and it is therefore possible to switch it off or have it on automatic so that it only comes on when it is dark.
Linuus
Linuus
crawley
w210 wagon
All the dome lights and interior light work except the 3 lights in the trunk
Linuus
Linuus
crawley
w210 wagon
still didn't found the reason why the lights don't turn on...
Linuus
Linuus
crawley
w210 wagon
Linuus
Linuus
crawley
w210 wagon
Found a bit of rust and water leaking from the rear window silicon sealing. So might need to add more to prevent infiltration.
Also checked the terminal and there’s continuity with the multimeter. I don’t have any voltage tho... so don’t know where to start the boots side light don’t turn ON too :/ any help?! @LostKiwi ? Thanks
Will try to get time to look at my 210 tomorrow.
Linuus
Linuus
crawley
w210 wagon
What lights come on when you unlock the car?
Front door will activate the front roof lights and the rear doors will activate the dome lights too, but the boot door won’t activate any light, nor the one on the tailgate, neither the one on the lateral inside the boot (pillars)
No I mean without opening doors or anything when you press the unlock button what lights come on?
Linuus
Linuus
crawley
w210 wagon
Only dome lights and front roof lights interior lights. Outside the 4 hazard light will blink once to unlock and twitch to lock the car.
Does the light in the back seat roof work?
Have you checked the fuses in the front fuse box? 3,4 and 19 from memory.
Linuus
Linuus
crawley
w210 wagon
  • #17
Yes, the the fuses working including 3.4 and 19.
And yes the light on the back work as well as the reading lights too.
Not the 3rd row of seat ( 2 on the boot)
I think you'll have to trace the wiring. Unfortunately I don't have wiring diagrams for it.
Linuus
Linuus
crawley
w210 wagon
  • #19
No problem, I will trace the wires o. My next sunny day ;)
