BlueRubber
Looking to change the rear diff oil in my 2013 E350 BlueTec AMG Estate
How can I confirm what specification of oil I need?
Thanks but I am hoping to find a non-merc branded oil alternative as £50 for 1L is daylight robbery!
Yep , that’s right , I use one of these as a pumpThanks for the info all, have ordered the oil.
I assume I don't need any gaskets or o rings etc?
Just need to undo fill plug
Undo drain plug and drain oil, then tighten it.
Then fill oil into fill plug until it starts to flow out then tight it and jobs a good'en?
Thanks, any idea what torque they need to be tightened to?The fill and drain bolts are extremely tight.
You'll need a breaker bar or equivalent.
Also you'll need a male hex socket. I had to buy one especially for the job.
50nm on both mineThanks, any idea what torque they need to be tightened to?
