S320 BAS & ESP warning lamps
Zeppelin
UK - Hampshire
2003 W211 E320 CDI * 1982 W123 200E
I have a 2001 S320 that has an ESP and BAS warning on the dash.
Replacement of the parking switch normally fixes this in most cases, I have had that done but it has not cured the problem.
It has now been on the Star diagnostics at a specialist and he tell me it has a canbus error and it may be down to a fault with the gear selector switch or the ignition switch??
Seems very odd...Not sure where to go from here??
I cannot believe this, does the guy know how to use STAR
I think more a BAS fault only as ESP cannot work without BAS
Z
Zeppelin
UK - Hampshire
He did not seem to want to investigate it any further, maybe he just wants the easy jobs??
I sometimes get the parking sensors flick on and a beep when coming to a stop at a junction, may this be related?
The Esp & Bas error is intermittent and does not show all the time.
There must be a BAS fault code logged, like brake travel sensor
Z
Zeppelin
UK - Hampshire
No codes given, he has just written the following -
Notes: Ignition fault possible electronic ignition switch and transmission selector module can lines.
OK the EIS is the master of the CAN, but so many things and never I think the EIS. OK it could be a CAN fault, but you need to go to the CAN circuits to see what is going on.
I do think that he did not wants the job, there has to be a fault listed, that is the thing
m3gt2
Leicestershire
'68 E220 estate Premium Plus, Command Online with Virtual Cockpit, soft close doors and full ceramic
Is this switch a common cause of this error then? I have had it 4 times in a week but twice today I assume the switch is under the dash, above the parking brake? Thanks
The parking brake switch can do this, and cheap to try but there are other things
m3gt2
Leicestershire
Thanks, I think I will give it a shot for the sake of a few quid!
£12 and dead easy to change :D
Z
Zeppelin
UK - Hampshire
Any suggestions as to where I go from here Television?
Many thanks for you input on this :)
I think a better indie with STAR, these things are not that easy without a direct code.
danbert748
New Registration
Cardiff
1999 E320 Touring
It's my first post, so bear with me....
I had a very similar fault on my 1998 E320 - BAS and ASP warnings, followed by other seemingly unrelated faults. I replaced the battery - no more warnings. A failing battery can affect the electronics. May be worth a try if you haven't replaced the it recently.
