S320 CDI Inlet port Manifold Linkages Seized
mouldb
Hi All,
The S Class Saga continues!!! No Turbo boost & Stuck in limp mode.......Took the car to the Stealerships for a 15 min diagnostic and they found the fault - Inlet port Manifold Linkages Seized. Does anyone know of a way of freeing them without taking the manifold off ???
Thanks in advance,
Bruce.
mouldb said:
Hi All,
Thanks in advance,
Bruce.
I do not get this, as the throtle part is all electric, there is no linkage to the turbo, I have looked here under injection and turbo.
http://www.detali.ru/cat/oem_mb0.asp?TP=1
malcolm
M
mouldb
Hi Malcolm,
Thanks for your reply! There is a series of 6 little plastic valves which are all linked to a thin metal strip the length of the manifold & a servo which is conected to the strip this is found under the inlet manifold and is therefore hard to see.
Hope this helps,
Bruce
M
mouldb
I Looked at the site too, and can't see anything which looks like it!
M
mouldb
A bit of AC90 and some wiggling & they are free....:) :) :)
