S350/2003- command unit not turning on at all
Can anyone help me with this problem?
  • Radio not working
    Votes: 0 0.0%
  • Air suspension
    Votes: 0 0.0%
  • Total voters
Omar1994
S class / 2003 / 3.7l
I have a Mercedes S-class 2003 3.7l and a few days a go I replaced the rear air suspensions and a new compresses aswell. Once the battery was reconnected the air suspension sign pop up on the dash board but when raising and lowering the car it works perfectly fine. But driving over speed humps or small pot holes feel very uncomfortable. The main problem is the command unit, I tried to turn it in but doesn’t seem to turn on. also the digital clock on the dash doesn’t show.
Can anyone help me, as I don’t know what’s causing this problem
'93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
Have you checked fuses? They'll be listed on a card in the fuse box or in your owners manual.
If you have the airmatic warning still on the dash, then there is an active fault code, probably to do with the valve block considering your hard ride.
O
Omar1994
Yeah I’ve checked the fuses and everything seems to be fine. Just don’t know what’s the problem
O
Omar1994
The vavlue, above the compress seems to be fine and no leaks just checked now
Not that its leaking, but that it has an electrical fault. You need to read the codes in the airmatic ECU.
Over 100 branches Nationwide, More than 114,000 Parts in Stock, The UKs Largest, and Fastest Growing Parts Supplier,please see MBO Members’ Area for discount codeEuro Car Parts Ltd
