S500l w221 2007 lovers
Brabus benz
S500l 2007 brabus 5.5l
I'm looking for some help my massage seats and lumbar supports don't work can't hear any air leaks could it be as simple as a fuse if where to find it ?
Probably a leak - when one fails the car will also block the other from working. On our SL it was a broken pipe under the seat from moving it back and forth. I sleeved it with windscreen washer pipe.
ajlsl600
france
i will find a position lovelly likes, for car seat,! and myself ,then make an effort to leave them like that, unless i have to get behind them . one less drama comming,hopefully
Mrs LK was in the habit of hitting the button on the seat to put her handbag behind the seat every time she got in or out. She's been re-educated....
Brabus benz
Brabus benz
Would the air leak be a loud hiss as I can't hear anything this why I'm thinking it's electrical
Thanks for all the feed backs
Couldn't hear anything on ours either.
We did hear the initial hiss when it first failed but that was all.
Once it detects a leak the PSE pump blocks the feed for any subsequent attempts.
Brabus benz
Brabus benz
Ok is the anyway of starting the pump to find the leak
Brabus benz
Brabus benz
I tried it using STAR but still didn't help. In the end I traced the pipework to find it.
We'll thanks again I guess that's what will have to do start with the driver seat etc if I find the leak and fix it will the pump kick back in or does it need rebooting somehow
I don't remember on ours to be honest but I did have to clear the errors. I just don't recall whether I cleared the codes first or after trying it.
Brabus benz
Brabus benz
Fingers crossed then that's for all your help
Ours was under the passenger seat. The plastic pipe comes from the seat and goes under the carpet. It was immediately obvious when you looked under the seat (put the seat on maximum height for ease).
