Sat Nav update
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Boydonegood, Nov 9, 2012.
  1. Boydonegood
    Boydonegood Senior Member
    396
    16
    Aug 13, 2012
    Rainham Essex
    Your Mercedes:
    CL500 2002 & C350 CDI 2010
    Hi guys
    Ive got a 2002 CL500. It has the smaller screen sat nav with an original 2002 DX Disc, which loads and works perfect (but well out of date)
    Ive purchased 2 "backup" discs from 2 different people of 2010 copies. These are both CD's and DX discs. Neither of them will load?
    With my disc:-
    Start screen shows "CD not available. Please insert NAVI-CD type DX." ...when I put my Gen "Tele Atlas Great Britian 2002 DX M1" CD in the screen changes to "Navigation being activated. Please obey all traffic rules." then changes to mapping and I can use sat nav..
    With your disc:-
    Start screen shows "CD not available. Please insert NAVI-CD type DX." ...when I put your disc in, the screen stays the same then ejects disc after about 20 seconds..
    If I turn off sat nav while that screen shows. Wait 20 secs then turn back on, I get the screen "CD-Reading error. Please change CD." and the disc does not auto eject.
    >Ive tried turning back off for 20 secs, but this screen doesn’t go
    Am i at a loss of trying, or am i missing a trick?
    Cheers guys
    Guess i should have just shelled out to start with and got the gen original.
    Cheers
    Tel
  2. toby1
    toby1 Senior Member
    4,848
    64
    Mar 13, 2007
    West Berkshire
    Your Mercedes:
    1998 CL420 C140
    Sounds like a Micky Mouse copy. Buy the real McCoy
  3. television
    television Always remembered RIP
    164,074
    285
    Your Mercedes:
    They are copies, and the early 2.5 will not read copies, you should send them back, if you can get hold of a 2010 genuine disc, they have TMC and very good
  4. OP
    Boydonegood
    396
    16
    Aug 13, 2012
    Rainham Essex
    Your Mercedes:
    Cheers guys
    Oh well, was wishful thinking then! Ill have to keep eye open for a 2010 original disc.
    Tel
  5. richardN2O
    richardN2O Senior Member
    629
    16
    Feb 14, 2012
    Guildford, Surrey
    Your Mercedes:
    CL55 AMG Kompressor
    I'm confused, are you saying that yours does NOT use a standard size of CD?
    I just bought a genuine Bosch CD/DX 2011/2012 set for my 2003 CL55 from a shop local £125.
    With these you can enter the first 4 digits of a post code, which is not ideal, but a vast improvement :)
  6. OP
    Boydonegood
    396
    16
    Aug 13, 2012
    Rainham Essex
    Your Mercedes:
    Yeah it's standard size, but think the newer versions are DVD?
    The backup/copy discs don't even spin up. But the original 2002 cd Dx does
  7. television
    164,074
    285
    Your Mercedes:
    No they are all the same size, the reflective qualities of the copies is not high enough for a 3 or 2.5 to read, and this has always been the case-
    The laser gain was set just high enough to read the real thing.
  8. maysons
    maysons Active Member
    31
    Aug 3, 2006
    Lake District
    Your Mercedes:
    2011 W164 ML 350CDI Airmatic Grand Edition.
    Sat nav
    Just to intervene this thread a little, I have just bought a Feb 2011 ML G Edition and wondered if there was a way to check the stealer has updated the maps when it was serviced mid November when purchased. Apparently it's free for first three years. In other words, will the system show the current maps update status. Cheers for any info.
  9. hawk20
    hawk20 Senior Member
    4,971
    7
    May 27, 2006
    Your Mercedes:
    ML250 BlueTEC Sport
    Free updates for three years on the new ML (166) but no mention of that on the old model (164) in any of the literature that I have seen. But Grand Edition and run-out models may have been different. Ask customer service?
  10. television
    164,074
    285
    Your Mercedes:
    You will be lucky if they did, most dealers never even turn them on to see if they work, and work on the premise the customer will bring it back if it does not
  11. Mic
    Mic Senior Member
    4,271
    127
    Nov 12, 2009
    Oxfordshire
    Your Mercedes:
  12. Chrishazle
    Chrishazle Senior Member
    3,263
    934
    May 25, 2009
    Nr Ashford, Kent
    Your Mercedes:
    I'd suggest first looking at www.comandonline.co.uk to find out what is the most recent update available for your system (don't know which version of Comand is fitted to an ML - NTG something or other, my 2008 S204 has NTG4).
    Then, assuming the engineers menu is accessed the same way as on my S204, press (all 3 at once) the phone hang-up, 1 and # keys on the main control panel (not the steering wheel buttons) and hold them for about 5 seconds, you'll hear a beep and the display will show the hidden engineers menu. Use the big silver button to access and scroll through, the small black back button next to the silver one to go back 1 step, you'll find the maps version in there somewhere. Mine said 07Q2 - 2007 2nd quarter (it doesn't now, but that's another story...)
  13. maysons
    31
    Aug 3, 2006
    Lake District
    Your Mercedes:
  14. television
    164,074
    285
    Your Mercedes:
    The DX versions are CD based from about 1998 to mid 2004, after this date they changed to the APS DVD system and the two are not compatible.
  15. hawk20
    4,971
    7
    May 27, 2006
    Your Mercedes:
    ML250 BlueTEC Sport
    In case the link ever disappears, important bits are:-
    MB Website 01 June 2010
    From model year 2011, Mercedes-Benz provides the new, free update for the navigation maps for new cars in all model series equipped with COMAND APS. This applies in 39 European countries, and for three years from the date of first registration. The price benefit for this map update amounts to several hundred Euro. Since it is vehicle-specific, this update entitlement is also transferable to the new owner if the vehicle is sold prior to the end of the three-year period.
    Thanks to the new map update program, the current map data is automatically uploaded during a regular service visit. Mercedes-Benz will also use the web to inform customers when a new update is available. On customer request, updates can also be provided by a Mercedes-Benz partner outside the normal service intervals.
    http://www.emercedesbenz.com/autos/...fering-free-comand-aps-map-updates-in-europe/
  16. television
    164,074
    285
    Your Mercedes:
    And the map updates from " Satnav disc" at £25 work very well, just updated mine, if any others require an 2011 update for the NGT3 then you are welcome to the disc free, you just then pass it on to the next one :D:D
  17. OP
    Boydonegood
    396
    16
    Aug 13, 2012
    Rainham Essex
    Your Mercedes:
    Have kinda give up using the incar Sat Nav..
    Not really blaming the system, but the road syatem has changed so much since my 2002 disc to today, unless i upgrade, it really has made my 2002 system obsolete.
    Guess ill have to buy a later disc when i see one, 2010 with the TMC would be nice, but am guessing anything newer may make using the system possible!!! but at moment any spare money is accounted for on trying to stop the wind noise through the drivers window!!!! Grrrrrr
    Cheers
    Tel
  18. richardN2O
    629
    16
    Feb 14, 2012
    Guildford, Surrey
    Your Mercedes:
    CL55 AMG Kompressor
    I had exactly the same problems, must be a CL thing.
    Think I said I got a 2012 disc locally, tried to make a copy, but as Malcolm rightly said, it didn't work.
    Drivers wind noise has been reduced using Gimmi Phfedge, but a small piece of the window rubber looks damaged, Idearly I need to compare with someone else
  19. OP
    Boydonegood
    396
    16
    Aug 13, 2012
    Rainham Essex
    Your Mercedes:
    Na, have tried 2 copy discs.. Both waste of time, then Malc advised that copies never do, so i gave up.
    Have just seen the gen 2012 for £150, but as say, the money is spent on other bits. Plus looking to change the Range middle of the year, so its essentials only at the moment.
    Did the Gimmi help?! Ive just brought some, havent tried it yet tho! Was it instantly noticeable?
  20. richardN2O
    629
    16
    Feb 14, 2012
    Guildford, Surrey
    Your Mercedes:
    CL55 AMG Kompressor
    Gummi made it better and did it just in time for our current freeze. As both CL & BMW are pillarless it made getting in that much easier. When weather improves I will add another coat of the stuff. We live off and are on quite a steep hill, so for now the cars are grounded, back to the trusty L200 4x4 :)
Share This Page
