It does work and that is the cure, just turn it up when she speaks for that few seconds and then turn it down when she stops talking, future announcements will then come through at that higher level proportional to the music
I don't know which version of COMAND I have, (W220 04/54) but the button to the left end of the row beneath the screen is the key. Set the radio volume to the level you want. When the Sat Nav comes on, press the button mentioned briefly (no need to hold it down) and then increase the volume. The volume for radio will default to where you set it when Satnav stops speaking, and that sets the differential between the 2.
