Incidentally, if I were doing their PR, I'd be saying: "Replace all these pumps now - end of. It's a no-brainer. The very least you can do to protect the brand."
Malcom, Martin is saying MB claim 27-30 percent and you are saying 10 per cent. Will be helpful if we could clear this up before I go on to MB. In any event, is even 30 per cent acceptable?
Another important point Malcolm. Can you confirm that message on white cluster DOES give you warning that pump is nearing end of its life? I was under impression - perhaps stupidly on my part - that it just goes with no warning (bright red). This is crucial.
In effect, if there is a warning procedure in place then that changes things considerably in MB's favour.
If that's the case then MB will make a spirited defence of the system along the lines of "It's a wearing part with a limited shelf life and the driver is given a warning of when it should be replaced blah blah blah..."
What drew me to this was the notion there was no warning other than when it failed and you were left with 10 per cent braking only. Appears not to be so.
I am also pretty sure at least 1 member here it went straight to red..no white at all.
Your mathematical calculations do not take into consideration the amount of sheer panic experienced by the driver who has the misfortune to try and stop this missile in a crisis... It wouldn't be so bad if he had a decent handbrake to fall back on..
I believe its VOSA who are the relevant agency.
There are two references to the SL and E class betwee 2001-2012 in respect of braking.
Reference : R/2004/094
Manufacturer Ref : p005
Make: MERCEDES BENZ
Model : E Class and SL
Launch Date : 05/07/2004
Numbers Involved : 39742
Build Start Date : 01/06/2002
Build End Date : 01/06/2003
Recall Details
Concern : POSSIBILITY OF REDUCED BRAKING EFFICIENCY
Description : Premature wear of the Sensatronic Brake Control (SBC) unit may lead to a reduced braking efficiency
Remedial Action : Recall affected vehicles, download the latest software. Following the download, the system will advise when the SBC hydraulic unit requires replacement.
AND
Reference : R/2005/134
Manufacturer Ref : P036
Make: MERCEDES BENZ
Model : E CLASS AND SL CLASS
Launch Date : 27/07/2005
Numbers Involved : 4700
Build Start Date :
Build End Date :
Recall Details
Concern : BRAKE PEDAL MAY REQUIRE MORE EFFORT THAN EXPECTED
Description : Problems may occur with the Sensotronic Brake Control (SBC) hydraulic unit that could affect the input required by the driver to stop the vehicle.
Remedial Action : Recall the vehicles that are likely to be affected so the SBC hydraulic unit can be checked and if necessary replaced.
So best to check whether your own vehicle has had both of these inspections. I called the original servicing dealer and he could only find the first for m car . Think I might give MB Milton Keynes a call
