SBC pumps
Clkrichard
Chichester
CLK 320 Cabriolet 2004, R 230 SL 500 2005, new A class AMG Sport.
I know that these can fail after a specific number of brake applications and that refurbishment is theoretically not possible.
I also know that having the counter reset is possible but means taking a calculated risk. I guess the warning message doesnt necessarily point to pump failure and more to the usage count though.
I also know MB have pretty much stopped contributing and replacement costs are the wrong side of £1,000.
My question therefore is one of prudent maintenance.
Can Star determine the number of brake applications left before the counter triggers the first warning ? I.e. can you get a degree of advance warning ?
Nope no rhyme nor reason on how it works some go 100's k miles others do not get past 50k. It has to be when the pump cannot reach the required pressure during the running time
_Taz_
Kent
2011 E63 6.3NA AMG Tenorite Estate MCT 7g
There is a counter in developer mode ( for some reason 300,000 cycles come to mind, probably more like 3 million ! )...
this is picked from the web... :)
In SD Developer mode you need to go to:
Entwickelingsdaten (developer data) ---> ansteueringen (control gear) ---> Gesamstliste aller Ansteuerungen (complete list of all the control circuits).
To see how many times brake has been pressed there is a line that says: Bremsenzahler (DJ_GetBrLive) (brake payer (dj_getbrlive)).
BUT, as Malcolm says... some SBC units don't even get 1/2 way to here & just fail ?
Maybe it's poor fitting technique, or I suspect people aren't renewing their brake fluids as per MB's schedule...
Mine certainly didn't look like it had been done... I suppose the theory is that it takes a hammering & as the fluid doesn't circulate as such, the fluid around the pump ( which I am hoping is also used as a lubricant ) breaks down slowly = wear.
The fluid is not pumped as such, it goes to the calipers as any other car and no return....they self check every 17 applications.
A car used in the rain will give a much higher usage count than one that never goes into the rain.
Distronic uses the brakes, just so many variables
C
Clkrichard
Chichester
Wonderful brakes but not one of MBs best engineering efforts then !
I have just had my fluid changed at 80k miles and the pump is covered by warranty for another 18 months so I will stop worrying for now !
The warranty will outlive my usage of the car ......
