scratch marks on screen
The glass polish as sold by "Frost" works very well,you only need the small packet as it last a long time.
You do need a power polisher with a foam head, the figure of 8 oscillating types are the best as the rotary ones send it everywhere
gordofski
gordofski
BOLOXNIA Nr. ALEXGRAD
www.dreamsdocometrue.co.uk
do power tools have to be used, or a good bit of elbow grease could do the job:D
That would be very hard work, even if you could,,the little sanders that go to a point on the bed are good and cost under £10
Yes that would do,, a battery drill would not be fast enough, and it would have to be mains powered.
smarty
another product available is jewllars rouge, this will however require elbow grease, but it works
Rappey69
hants
c220 w204 amg sport
A rotary buffer is used with jewellers rouge and it does around 120 rpm !
the wheel has to be soaked with water when in use else it will make more scratches..
Excessive use in one area will put a dip in the glass as it grinds it away but the glass will remain perfectly clear.
As stated in previous post, it can be used with a water soaked cloth and elbow grease but will take a while.
Dosco
W211
I keep reading about 'Elbow Grease' where can one purchase a tin or jar;)
turbopete
Spennymoor
they were THROWING it in with the deal since their elbow was so well lubed!
turbopete
Spennymoor
They were counterfeit!
Genuine elbow grease is very hard to find these days.
Russ
i wasnt aware that theyd managed to copy it yet!!
