Sd nav card
Rywalk1982
C Class estate
Hi I've just purchased my first mercedes C class it's a 69 plate 1.5L AMG Line EQ Boost C200 the larger screen it didn't come with an SD card for the sat nav are these main dealers only or can I get one from elsewhere any help appreciated
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
sl500amgsport
Essex
SL500 2014
That new you should be able to subscribe for the nav package using digital extras with Mercedes me, take out the monthly subscription or 1 year and the nav will automatically update over the air..Once fully updated you can cancel.
Sent from my SM-G988B using Tapatalk
R
Rywalk1982
C Class estate
If that’s the case that will be brilliant I pick up 16th so will have a good research and a good play do you think I’d need a SD card doing that way? Or will it be straight to the navigation?
Best regards
sl500amgsport
Essex
SL500 2014
Best regards
Make sure your local dealership change the Mercedes me ownership details as the car needs to be registered to you to purchase the digital extras.
sl500amgsport
Essex
SL500 2014
I’m not sure a 69 car will do over the air updates. My 68 doesn’t and it’s the same platform as the C class.
My 2019 E class does, works very well, I think there were major changes between 2018 and 2019, you need the 4g module can check against vin number...
Srdl
New Forest, Hampshire
GLC43 AMG 2018 (X253)
Yes, I have 4g module. Depends on the NTG system, GLC and C had NTG5*2 but that may have changed with the face lift
www.ckinsurance.co.uk
