Self Levelling Suspension on a W210?
RANA_1
What do I check to see if I have Self Levelling Suspension ?
W210 E320 CDI Estate.
Also the Power Steering fluid was at min so I have topped this up with
MB Power Steering Oil/Lubricant A 000 989 88 03, if I have Self Levelling is this tank also supply the same suspension ?
thanks
ohlord
Wagons
self leveling rear suspension.Yes same tank.Monitor it for a bit to make sure you have no leaks.
ohlord
jp williams
Wirral & Axarqia,Spain
2002 E class 2.2 cdi auto estate, Lexus GS 450h
thanks
Put your VIN into the english version of the Russian website and it will tell you if you have the self levelling suspension.
Regards
John
R
RANA_1
Thanks John. Yes it has.
The top tank is actually labelled Central Hydraulic, does it matter that the fluid put in is not exactly the same i.e. I thought this top tank was for power steering so I put in the specific fluid - which was purchased from MB.
BTW how do you drain the fluid and how often should the filter in the reservoir tank be replaced ?
Thanks,
RANA
