Service advisory Blocked bulkhead drain
BartyM
E Class Cabriolet E 220 CDI SE 2014
Just been advised that my Bulkhead drains are blocked on E Class Cabriolet E220 CDI SE.
Is this something that I can resolve myself or will I need to book the car in for Mercedes to sort out.
Thanks in advance.
Just clear all the gunk from the scuttle panel at the bottom of the front windscreen, hoover out the debris if possible.
Ensure water poured into the windscreen does not pool and drains properly.
You have now saved yourself £85 :)
ajlsl600
france
exactly, follow that !! there likely times you need intervention ,this aint one of them ...
EmilysDad
Bury Lancs
ML350
I wish I'd known the scuttle drains on EmilysMum's Citroen were blocked ..... if only Citroen hadn't thought to hide 1 of the 3 out of sight under the wiper mechanism :(
star
Reading
Smart + others :)
We didn’t they unblock them at service. It’s done foc with us.
Ditto. Seems ridiculous to mark it as a seperate job!
R171 SLK280, Smart R451, 997 C2S, VW ID.5, R1250 GSA TE 40th, CBR600FP
Because then they can charge for expensive module replacement because of water damage...:rolleyes:
B
BartyM
I’ll mention it to them. Cars due back so I’ll attempt to unblock them myself. Thanks for the info
V6Matty
Newark, Nottinghamshire
Ah but a dealership will say due to blockage the system needs replacing, not just cleaning ;)
brandwooddixon
Wolverhampton
S63 Coupe 2014
Buy yourself a length of net curtain wire, say about 1.5 - 2 metres.
You can then use that to thread down the drain channels in various places and with a little water it will clean them out.
mioba
Nottingham
what kind of garage would mark that as an advisory.
That is a pee take.
Name and shame?
www.W140.co.uk&www.r129.co
