service brake indicator for 2006 cls500
Discussion in 'Suspension, Steering & Brakes' started by fersoz, Dec 6, 2012.
  1. fersoz
    fersoz New Registration
    Dec 6, 2012
    medford
    Your Mercedes:
    CLS500
    I have changed my pads and sensors on my 2006 cls500. i changed 2 front sensor and 1 rear sensor. i still see "service brake" error on my dashboard. Any idea how to reset this ?
  2. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    The system is still open circuitit could be a faulty sensor.
    easiest way to check is to unplug the sensor from the chassis end and short out the two holes in the socket with a piece of wire, then check the dash again, the one that puts the lamp out is the falty sensor
  3. star
    star Forum Supporter Authorised Forum Supporter
    5,557
    1,005
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    Get your sbc brake system read. Do a search on sbc.
  4. moe4cool
    moe4cool New Member
    Feb 12, 2014
    Calgary
    Your Mercedes:
    2006 CLS500
    How to reset
    1. Ensure all the sensors are installed properly (Two front sensors are different, there is one for the right hand side and one for the left hand side. Right one will not fit on the left side and vise verse.
    2. Put the key in ignition turn it on but do not start. Go to the error message.
    Press the reset button for about 5 seconds. (Reset button is the knob located next
    to the cluster)
    That should fix it.
Share This Page
