Service items - buy yourself or leave it to garage?
Discussion in 'General Mercedes-Benz Related Discussion' started by rexemper, Feb 7, 2019.
  1. JBell
    JBell Senior Member
    9,358
    1,707
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    100cc out on the engine size though (winky face)
    Wighty and John Laidlaw like this.
  2. LostKiwi
    LostKiwi Senior Member
    15,603
    6,448
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Any car with a limited slip differential should have regular diff oil changes (not just AMGs).
    This is due to friction clutches internal to the differential wearing and contaminating the oil with particles of friction material.
    rorywquin and Jimbo1959 like this.
  3. Wighty
    Wighty Senior Member
    5,193
    2,431
    Aug 4, 2016
    Your Mercedes:
    I dream of having an LSD equipped car (a fast one anyway)
    Capra likes this.
  4. Wighty
    5,193
    2,431
    Aug 4, 2016
    Your Mercedes:
    Close enough for Government work buddy (smiley face)
  5. LostKiwi
    15,603
    6,448
    Aug 25, 2006
    Your Mercedes:
    Loads can be broken down into three distinct types:
    1. Friction LSD where there areca set of clutch plates under a preload tension. These will drive both wheels at the same speed until a preset torque difference across the axles is reached at which point the clutches will slip but still drive both wheels.
    2. Locking diffs. These use a panel mechanism to lock the wheels together. The pawls allow a wheel to go faster than the driven wheel but prevent the wheel going slower. They tend to be very noisy..
    3. ATB or Torsen differentials. Automatic Torque Biasing or Torque Sensing differentials use a series of helical gears to detect a slipping wheel and direct 3-4 times the torque of the slipping wheel to the opposite side.
    Each have their benefits and drawbacks. Locking diffs are severe in their operation and noisy (especially at low speed in tight turns) but provide 100% drive to both wheels when operating.
    Friction LSDs are adjustable by setting the clutch pack preload and are smooth in operation but require higher maintenance.
    Torsen diffs require some grip on the spinning wheel in order to transfer torque to the opposite one but are arguably best suited to road cars.
    There are also electrically operated locking diffs. These are commonly found in off road vehicles where permanent full time drive is required to both wheels.
    Wighty likes this.
  6. Blobcat
    Blobcat Moderator
    10,290
    1,076
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    Or air operated ARB lockers....
    rorywquin likes this.
  7. LostKiwi
    15,603
    6,448
    Aug 25, 2006
    Your Mercedes:
    Good point. Forgot about them.
  8. DSK
    DSK Senior Member
    61
    29
    Jan 31, 2019
    Your Mercedes:
    CLS 320 CDI
    Personal opinion and experience;
    2 new cars on lease (Merc E350 and Astra GTC diesels, 3yrs 90,000 miles on each). Took them to the local dealer for servicing. Waited ages for basically an oil change. They do the filters and other items every few services and charge a fortune for the actual work they carry out. Generally speaking I have found most dealers to be shoddy with very little knowledge and I hate the fact many treat customers like they know nothing.
    On any car I own myself and family members cars purchased new outright, we use independent garages known to me/diy. We buy the parts, ensuring each service genuinely consists of premium oil, plugs and all filters at the very least. This way, all service parts like air filters etc are sure be at their optimum performance between services. I also find that it's costs the same (with labour) to do it this way rather than get just an oil service at dealer. Every 2 or so services the gearbox oils for automatics and manuals, coolant, brake fluid etc are also done. This way for the normal cost of a service, ones service items and mechanical components are in better shape than a 'dealer serviced' vehicle.
    daibevan and Wighty like this.
  9. alexanderfoti
    alexanderfoti MBO Forum Supporter Authorised Forum Supporter
    10,697
    1,367
    Mar 25, 2010
    Dartford
    Your Mercedes:
    LSD's scheduled, non LSD;s are 150k I think.
    Wighty likes this.
  10. Wighty
    5,193
    2,431
    Aug 4, 2016
    Your Mercedes:
    150k buddy , most MB's will be a bucket of rust by then !
  11. alexanderfoti
    10,697
    1,367
    Mar 25, 2010
    Dartford
    Your Mercedes:
    Or 15 years :p
  12. Wighty
    5,193
    2,431
    Aug 4, 2016
    Your Mercedes:
    Wighty Motor Services have done both their MB's rear diffs twice already !
    alexanderfoti likes this.
  13. Jimbo1959
    Jimbo1959 Senior Member
    720
    424
    Mar 22, 2018
    Ayrshire
    Your Mercedes:
    E350 CDi Blue Efficiency Sport Coupe, fast, smooth, comfortable, what more does one need?
    There are plenty of tutorials available for reference and study on YouTube Andy, most service items, oil, air, fuel and pollen filters are demonstrated and are fairly straight forward to do with a pretty basic tool kit sir.
    I was pleasantly surprised at how easy they were to do by myself. Have a look, it will help with your confidence and encourage you to learn and diy.
    Capra and Wighty like this.
  14. Altamar
    Altamar New Member
    9
    9
    Dec 28, 2018
    Your Mercedes:
    2014 E Class 220D saloon & 2015 SL400
    I try to find a best of both worlds compromise. As others have said, it partly depends on the value you place on a full MB service history. I have a 15 plate SL (and a 64 plate E Class) and have persuaded myself that no-one is going to buy an SL in a few years time without a full MB history. However, on both my cars, and all the family cars (different brands), I tend to keep the history up in the sense of getting the oil service done through a dealer but I buy quality parts and do the air/pollen filters and also brakes myself. You really can save yourself loads of money on these ancillary items. I made the mistake of taking a service plan out on the E Class but that's a different story and I won't be renewing it as I now know it hasn't saved me anything.
  15. Capra
    Capra Senior Member
    2,024
    442
    Jan 27, 2018
    Gloucestershire
    Your Mercedes:
    W204 2013 C350 CDI Pan roof
    If I had the space the tools I would be happy about giving this ago. But I would need jacks, stands, and a flat surface. Our drive is on a slight incline. So I look at this and the costs for asking a pro to do this and I am swayed. But, I could do pollen filters, air filters and could do the oil filer and oil with the oil pump.
    daibevan, Wighty and Jimbo1959 like this.
  16. Wighty
    5,193
    2,431
    Aug 4, 2016
    Your Mercedes:
    My drive is a slight incline , I use a couple of wheel ramps from Halfords (£40?) , when I back the car into them or drive onto them with the ramps on the lower part of the slope , the effect is to make the car level but with the front or back up in the air with reasonable space underneath .
    I can do rear diff , gearbox filter and drain oil from underneath just with the two wheel ramps . My point is you don't need much gear if the drive "happens" to be at an angle .
    Capra likes this.
  17. Capra
    Capra Senior Member
    2,024
    442
    Jan 27, 2018
    Gloucestershire
    Your Mercedes:
    Would you just check online to see what is required at certain millage? Apparently you can download the infor from the cars service history. Maybe I will look at this over the next years or so, I have the first indie service in April, so I will see what the total costs are. Mine is a 2013 model, so in a few years keeping up a full history will be pointless.
    Wighty likes this.
  18. Wighty
    5,193
    2,431
    Aug 4, 2016
    Your Mercedes:
    I tend to know what my cars require service/filter wise from reading far too much stuff over the last few years . I tend to "over service " when left to mine own devices though .
    I've got 2x2009 cars so they are fast becoming old bangers , but good condition ones none the less .
    Capra likes this.
  19. Blobcat
    Blobcat Moderator
    10,290
    1,076
    Your Mercedes:
    With a private plate they're never "old bangers"!!!!!
  20. Wighty
    5,193
    2,431
    Aug 4, 2016
    Your Mercedes:
    One has , one hasn't (smiley face)
Share This Page
