I have a Y reg A160 which I had serviced by a non main dealer, not realising that it would give a service warning every time I subsequently turned on the engine. Is there any way I can turn this off?
Thanks for that. I went to the car and tried it several times but the problem is still there. It shows a spanner symbol with a number which increases daily.
You could try;
Active Service System
1 Turn electronic key in the steering lock to position 1
2 Operate the system selection button (on steering air bag, left side bottom button) until the complete overview (total mileage and trip odometer) is displayed in the instrument cluster.
3 Operate the arrow button above the selection button until the service symbol and the actual remaining mileage, time, or service exceeded indication is displayed
4 Press the (R) button on the instrument cluster for about 3 seconds until the message "DO YOU WANT TO RESET THE SERVICE INTERVAL?" CONFIRM BY PRESSING THE BUTTON appears
5 Press the button (R) again within 5 seconds
6 The message "Remaining mileage" of 10,000 Miles or 15,000 Km will appear
That won't work. Its for a different model.
1. Ignition to position 2
2. Press "0" on cluster quickly twice (double click)
(the service remaining will show up)
3 Then off with the ignition.
4.Hold the "0" down and turn the ignition on again and wait 5+ seconds.
The interval will then be re-set with a beep.
Hi BlackC55
Could you please give me the sequence for my other half's 230SLK - 1998
BlackC55 any input please :?:
Hello.
Are you with the car now?
Phone me whe with the car and I will talk you through it.
