Servicing and fault finding
jim
Can anyone advise me on a decent place to get my 1988 190E serviced in or near Brighton ?
Ive just got the car and would like to find out what sort of nick its in (It looks great from the outside and drives like a dream!) - what is the best service to ask for?
Is it worth getting this age car regually serviced or should I just change the oil and filters?
I hope you can help - Im really impressed with this car so far.
Matt Crooke
Essex UK
A lot of people who arent into Mercs would say that, whats the point of getting a 14 year old car regularly serviced. However we all know that a properly looked after Merc will outlive most other cars on the road, especially the slightly older types like ours.
I would recommend a full service as a good point to start at, but make sure you take it to someone who has at least some knowledge of mercedes, as i wouldbt be able to sleep if i handed mine to somewhere like a Lex Autocentre, which are used to servicing Mondeo's like a conveyor belt.
I cant recommend one down near you, but im sure an internet search, or someone else on here will be able to tell you.
Well done on the new purchase!
jim
Thanks Matt
- ive found a place who specialise in BMW and Merc servicing and they say they will do a full service for £200 - bit better than the £450 from the Main dealer!
Is this a fair price for a service and what should I expect for this ?
Matt Crooke
Essex UK
I jim, yeah i know what you mean about the price of dealers!!!
For a full service i would imagine....
Plugs
Leads
Oil Change
Oil, Air and Fuel Filter change
Auto box oil change, including the converter
Back axle oil check and renewal
Brakes All round
Check of all running gear.
They are the basics that i would imagine will be included. Your best bet is to get a service checklist from the garage to see what they actually do. Andy Gale would also be able to tell you if anything more / less is included.
cheers
Tomkinsm
Jim,
Please would you give me details of the garage you found? I'm in Brighton and looking for somewhere good..
shazam
New Registration
no power and loud fan??
The revs do not go over 3000, and as a result there is no power, also the fan is soundin really loud, any idea anyone? i own a 2001 C220 CDI...sounds like its on its final legs (or wheels)!!
any assistance would be geatly appretiated
dieselman
A diesel
You should've started a new thread for your issue.
I assume by 'the fan sounds really loud' you mean the turbo charger is blowing hard, if so suspect a split boost side intake duct or split intercooler.
grober
Scotland
W204 C200cdi estate
Plugs
Leads
Oil Change
Brakes All round
cheers
As suggested above with the exception of the plug leads which are usually OK and quite expensive to replace with OEM quality. I would also clean the rotor arm and distributor cap contacts, check the power steering fluid level and poly V belt for wear and tension. Depending on when they were done last and type --coolant/antifreeze mix----and brake fluid. It might not be a bad idea to get it MOT tested which will check all the steering and supension ball joints are OK and the exhaust/catalytic converter [ 88 maybe not fitted??]are working with no leaks.
Oil and filter change 6,000 mile interval
Autogearbox fluid and filter 36,000 miles
Fuel filter the same. 36k
Air filter -depends on conditions but 18-24,000miles
Brake pads last about 12,000-18,000 miles dependent on use.
back axle oil 50,000- 72,000 miles but many never get changed unless they leak
poly V belt 36,000miles unless damaged
Oh and join this forum also http://www.mercedes190.co.uk/
and buy this HAYNES MANUAL http://www.haynes.co.uk/webapp/wcs/...10001&storeId=10001&productId=12997&langId=-1
