Sidelights too yellow?
Miffy
Bromley, London
CLK 320 CAB Elegance C208
I had upgraded my main lights to a better output, still halogens though. I found that my sidelights now looked very YELLOW
SO, after looking around I found some nice LED side lights. Found these
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280305269434#ht_1986wt_982
As they draw too small a current for the lights warning system to detect, I had to fit a pair of these resisters to create a greater current draw.
http://cgi.ebay.co.uk/10w-LED-Resis...ash=item41458fe7fc&_trksid=p4634.c0.m14.l1262
Now, I have no light errors, and a nice non yellow sidelight. the light on the left is the stock bulb, very yellow, the one on the right is the LED
Very nice and it does look better
rf065
Grossbritannien
You can buy white sidelight bulbs as well, Philips do them, 5w & look just like your LED's.
Russ
Miffy
Miffy
Bromley, London
Russ
I did try some Xenon(gas not discharge) white sidelights, still very yellow
rf065
Grossbritannien
I used Philips Blue Vision W5W for the sidelights which matched the Philips X-Treme Power headlamp bulbs. If they were a bit cheaper I'd do the fog lights to, but hard to justify replacing two bulbs I almost never use anyway.
Good site here for bulbs.
http://www.powerbulbs.com/index.asp
Russ
silver CL55
Hamilton, Scotland
W216 CL500 2008. R230 SL350 2005
Can you show me how to fit the resistor?
I bought a pair of " no error" leds but they are showing an error sometimes.
colin.
Miffy
Miffy
Bromley, London
That will do nothing but dump current when the lights are on. If you want a voltage divider, and I imagine you do, the LED & resistor need to be in series
Nick Froome
www.w124.co.uk
No, you dont want to drop the voltage, as all of the car LED systems are wired for 12v, what this does is create an extra current draw which the canbus uses to check if the lights are working, if you wire in series, the lights will not illuminate at all.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Ah.....
Nick Froome
All LEDs are 3.6 to 5 volts near enough and 3 are wired in series to make up the 12v most consume about 30m/a, so that is 3 LEDS for the 30 m/a
roadhog
Sunny Norfolk
W124 300D x2, C124 300
I was just about to ask if this would work on my W124 but then I saw the price of the resistors, couldn't possibly be that extravagant on my low cost motor. :D
They only cost £1.20 from CPC
i must admit those LED lights do look better than standard. might try something like that myself if/when i need to replace bulbs!
