Signals, intermittant wipers and hazards cut out
Status
Not open for further replies.
GLG7
When the temperature outside is over 6o degrees F. My signals, intermittant wipers and hazards cease to work. I've had two shops look into this and they cannot locate the problem. They have checked the connections and grounds. This has happened probably 15 times. Any suggestions?
guydewdney
Tring, Herts
www.atct.co.uk
what car?
most mb's have all these functions on one relay - the multifunction relay - quite an expensive relay - like 40 quid iirc, and a known problem :rolleyes:
G
GLG7
Thanks. '97 C230.
guydewdney
Tring, Herts
www.atct.co.uk
item is unit 119, part no 202 820 46 26
does the rear window heater give up as well? it should be the same thing
G
GLG7
Thank you much guydewdney. I'll try that.
G
GLG7
Thanks Andy. I think guy is correct though. It happened again on my way home from work and I checked the rear defrost as guy mentioned and it too didn't work.
GLG7
Status
