Skirt and underbody floor cover damage
sgript
A Class W177 A180D 2018
Hey,
I unfortunately have some skirting and underbody floor cover damage on driver side. I’ll probably need bits replaced as a chunk on the underside of the skirting has snapped off and has also dug/damaged a bit of the underbody flooring cover.
See video:
Is this a job only fixable by the official Mercedes body shop and does anyone roughly how much it would be, with the skirting and that panel on the underbody floor cover needs replacing?
Hello and welcome,
Any decent bodyshop should be able to fix that - if you can get it up on axle stands (safely) you could probably just unbolt that plastic trim and replace it yourself. You might even be able to plastic weld what you have and make an almost invisible repair
ajlsl600
france
You might get lucky if remember correct mb top 120 for a missing plastic under pan, half of front on my Vdoz .
sgript
Hello and welcome,
Unfortunately the piece I had to cut off as it got really badly bent/twisted and was scraping against the ground, so I suspect it will be replacements
sgript
Fingers crossed!
I went though some deep water in my smart and damaged the undertray and side skirt. I took it off, plastic welded and stitched it together - unless you go under it you can’t tell.
mioba
Nottingham and Köln
Thats just a protective panel made of plastic.
Easy DIY if you are inclined. Scree on and off.
Ask MB how much they would charge to replace.buy the part and go to any garage with a lift - so min job.
sgript
Do you know where I can source the parts? I tried having a look but had no luck :(
Call Mercedes Grangemouth or Newcastle
00slk
Cambridgeshire UK
The side skirt is repairable, however if there is any part of the damage on your skirt is missing, that's a different story. To get a piece to replace or make up the missing piece, you will have to source the exact plastic type. Otherwise trying to weld to different types of plastics together is like welding steel to cloth.
Best to track down a second hand skirt from a breaker.
I've still got my damaged skirt, waiting for another of the same skirt to repair mine.
