Sl 129 door window motor
e55amggary
Bristol
C220cdi sport edition Auto / A6 2.7tdi Quattro s line Avant
Hi,does anyone know how to remove/replace a window motor on a 1997 129 model,drivers side?I took the inside trim off,but no chance.Do you have to remove lower door moulding???Also will a faulty window motor affect my roof?It seems to have stopped working.Thanks Gary
Hi gary,,yes the roof will not work without knowing where the window is, thiough you could put it down manually.
I will find you a work sheet for the motor
e55amggary
e55amggary
Bristol
sl 129
Have put window down,window only playing up last few cm,s where it comes into contact with rubber seal,You can hear motor grinding/slipping.Back of roof comes up,but front will not unlock??and roof switch flashes??All help appreciated.
e55amggary
e55amggary
Bristol
Also after the part no.for drivers window motor,august 97 320.
I have sent you the window adjust paper that I had, and more should follow, as before if the roof does not know where the window is the top will not come down
e55amggary
e55amggary
Bristol
sl 129 window motor
Thanks malcolm ,i have new e mail addresse gary.morris52 @yahoo.com
They have been sent to the ones in your signature and that is the same as the one that you have put up
davidsl500
Home : Derbyshire at the moment !
R172 250CDI Gone..!, R129 SL500 Gone...
If the windows goes up allright apart from the last few cm's and knocks/slips back then its the window regulator that is worn - missing a tooth or 2 no doubt. The gear on the motor may also be worn.
e55amggary
e55amggary
Bristol
sl window
Thanks for info,what is a window regulater and what sort of money are we talking?
e55amggary
e55amggary
Bristol
sl 129 windows
Thanks everyone.Fault was window regulater aswell as motor.Wanted it fixed asap,so had mercedes of bristol sort it.New motor and regulater fitted £480!!!They did say roof problem was seperate issue possibly pump.But as soon as window corrected,roof fine again.Thank god.Was a bit pricey,but the service they gave was excellent.Even had strawberrys with cream watchhing the tennis.They were working on car for 6.5 hrs!!
Pleased that it is all fixed :D:D as before the roof cannot work if it does not know where the roof is
