Can anyone help please? I have a SL 320 R129 model and need to replace the boot lid LED light unit. Can anyone tell me how I can remove the existing unit.
You've probably checked this, but.......the most common fault with these is broken wiring, where it passes from the body to the boot lid, inside a sheath clipped to the hinge.
If you do have to replace the whole unit, you need to remove the trim inside the boot lid.
If it's just the lens that needs replacing, it is possible to clip it in carefully from outside, without dismantling the whole thing.
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
