sl 350 heater
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by pez47, Nov 30, 2012.
  1. pez47
    pez47 New Member
    3
    Nov 13, 2012
    grimsby
    Your Mercedes:
    mercedes sl 350
    when i turn on the heater switch on this sl full the bars only light up half way then around 2 to 3 minutes it will come on full also the air con when switched on flashes a couple of times then goes off any suggestions please
  2. Fleetwood
    Fleetwood Senior Member
    163
    Jun 20, 2012
    Horsham, West Sussex
    Your Mercedes:
    2005. SL350
    Could possibly be water under the passenger carpet
    Open the bonnet and under the passenger bonnet grill is the heater box check to make sure there is no water sitting in there
  3. toby1
    toby1 Senior Member
    4,901
    170
    Mar 13, 2007
    West Berkshire
    Your Mercedes:
    1998 CL420 C140
    I may be wrong but I think it does this by design to allow the engine time to begin to warm.
    IIRC there was thread on this very subject recently. Others will advise or you can search the forum yourself. Or the info may even be in your owner's manual.
  4. Fleetwood
    163
    Jun 20, 2012
    Your Mercedes:
    2005. SL350
    I'm going out in my SL tonight so will try it and report back :)
  5. drmw
    drmw Moderator
    3,683
    112
    Nov 25, 2007
    Yorkshire
    Your Mercedes:
    are you getting "consumer electrics offline" when you start? If so, it will prevent full power on several things including the fan & rear screen heater until the battery in the boot gets up to charge.
  6. WG M-B
    WG M-B Senior Member Authorised Forum Supporter
    3,105
    6
    Dec 5, 2010
    North west london
    Your Mercedes:
    C63 Wagon in black
    I would imagine the fault to be caused by the heater circulation pump. This fault shows on star
Share This Page
