H
hugo4396
Hi Guys,
Having not used my SL 500 over the winter very much I went to put the roof down . The roll bar moved to the up position at the start of the cycle and locked. I could not move it one way or another. Eventually I found my way to this site and followed the advise on the forum . I held the manual roll bar button in the up position for 12 secs and heard it click and reset. the roll bar was then able to go up and down.
However when the roll bar is down whether the roof is open or closed the red warning light on the dash flashes. If I manually raise the roll bar the warning light goes out. The same applies when I use the roof control the cycle finishes with the roll bar in the up position ..if I then manually lower the bar the warning light flashes. It seems to be out of sync.
I took it to a Merc specialist who got his machine out to try and clear warning lights it did not work...
If anyone can advise how to clear the warning lights and sync the roll bar again so the roof opening and closing cycle finishes with the roll bar in the down position I would be ever so grateful.
Thanks in advance
Thanks in advance
