An age old problem. My pump has gone and needs to be replaced and wondered if anyone had one that worked that I could buy. A new one is quite expensive. Thanks
Agh! well thanks for letting me know. Same old issue, water ingress and keeps blowing fuse even when i dried it out so rather than tinker with the innards am looking to replace it. Might also have an issue with the roof as that does not work, but think it might be related as roof does not open if boot is locked
It has to know the boot is closed and the load cover must be down for the roof to work. There is no direct connection between the roof and the PSE pump.
It is probably the motor pulling too high current if the fuse keeps blowing rather than anything on the PCB. It might be possible to change the motor over or clean it up
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
